As some of you know, I've started removing my b3 from my Aspire, it's also been tore down to the shell on the outside, and the only things remaining is the suspension/seats/carpet/and dash, which will all come out eventually.
My plans are to turbo a BP and make about 200 hp with it, I know it's not going to be easy, but with time and your help, I think it can be done.
Let me be clear, I don't know what I'm talking about. That being said, please let me know if something I say is off, so I can do this right. Even with all the time I've put in researching on here and in books and on the web, mistakes are going to be made.
I've already done some things to the car, the list includes but is not limited to..
General Maintenance:
new speedometer, old one quit
new driver side drive axel
NGK V-Power Spark Plugs
Regular Oil Changes every 3k-5k mi. (5w-20 in winter/5w-30 in summer)
Fixed front bumper (bottom was ready to fall off)
Headlight Lens Restoration with Maguiars Polishing Compound & kit
Patched fist sized hole in rear pillar plastic
New Lower Control Arms (driver AND passenger side)
Upgraded LCA bushings to Moog polyurethane bushings (K9737)
Driver Side Tie Rod End/balljoint
Freed up/Antiseized E-brake levers Replaced E-brake levers on driver side
New Drum Brake Spring kit on both sides
Tightened up Clutch Cable Flushed Coolant System, new 50/50 mix
Fixed Crossmember-Frame Mounting Bolt
Popped out fender dent & bondo'd
Cleaned/sanded and painted hubcaps
Painted Windshield Wiper Arms
Modifications:
02 Kia Rio front strut/spring swap
Cold Air Intake w/ custom corroplast box
Power Door Lock Actuators
Power hatch Actuator
Keyless Entry System
Aftermarket CD Player (looking to upgrade)
1000w Sony Xplod Amp
12" DVC Rockford Fosgate Sub
6" Xplod Speaker Upgrade in doors
Custom Dash Buttons, one toggles sub/amp, one toggles hatch popper
Keyless REMOTELESS Entry (top secret need marsec lvl 3 clearance)
Blue Dash Lights
Aftermarket Tachometer install
Aftermarket Vacuum Gauge
Painted rear half of interior Panels
Spare Tire delete
Most of that can be seen in the build threads on fa.com
Old thread
New Thread
And more pictures on my photobucket account, should be public, feel free to browse the pics..(let me know if this link fails)
So, my goal is a 200 hp BPT, but for now, I need to get the motor and get it ready to be turbo'd, which will include freshening up the motor and some work on the head. I've been looking for a donor car, but haven't found one yet, car-part.com has a few engines within 100 miles of me, I'm looking for an escort GT motor because I want the Ford valve cover.
They have a couple 91's a couple 94's and a couple other years, I heard you want an early bp motor, so a 91 is what I'm after right?
I'll also need a distributor, starter, alternator, and intake manifold from the same engine, anything else? I plan on running a MS system, so the vaf isn't needed. Anything else I need to know before purchasing the motor?
Modifications:
Blue Dash Lights
Spare Tire delete
Old thread
New Thread
