b3 header & cai pictures
  • b3 header & cai pictures
    this is my header & cai that i built
    PROPOGATE! AND FACILITATE!
    Nice job! That intake is not taking in a lot of cold air though.
    Oscar
      thanks. but ever notice the amount of air that comes thru the right side of the grill, the huge void between alternater & firewall & area thru splash liner? only has to fill 79 cubic inches, mod made noticable seat of the pants difference.
        nice, puts my rusty header to shame lol... looks like the same shape tho... where is the collector?
          Would you consider building headers for other peoples' B3s? I could use one or two.
            here is the collector. yes i can manufactor this header.
              Wish I had one...........
              ........... With a lever long enough and a place to stand, you could move the world..........
              ..................Build thread.................http://www.fordfestiva.com/forums/sh...ad.php?t=29547
                that must sound mean... when i switched to my header it gave it a deeper tone... any sound clips of it?
                  What pipe diameter re you using for the 1.3? Also, can you make it with a flange to mate up to the stock cat at the stock location, so it's a simple bolt-up? How about a bung for the O2 sensor? And how much would you charge?
                    I'm also interested in the answers to these questions.
                    -85' Nissan Sentra 5 spd.
                      ^^again
                      -Josh R
                        I would also like a couple. Tired of waiting for the "other" guys to do something.
                        Chuck
                        Life's a beach, then you marry one---- Shakespeare
                        If money will fix it, it's not broken
                        91 GL -Ol' Rusty
                        93 GL - Lil Red
                        91 L - Tweetystiva
                        http://www.fuelly.com/car/ford/festi...tfordcat/54176
                        http://www.fuelly.com/car/ford/festi...tfordcat/54596
                          Jesus that header looks like it was made for something a LOT more than a b3.
                          How bout one with a T3 flange and a wastegate flange on it.
                          91GL BP/F3A with boost
                            l designed this header to work w/mildly stock 1.3 engines. w/that in mind, my figures came up w/1.375 in primaries & 28 in primary length. The primaries are arranged in the collector in proper firing order to promote all around performance & drivabiltiy, scavaging. VE(volumetric efficiency) w/this header is around 4000 RPM. l also biuld a stepped header for highly modified egines that has 1.375-1.5 in primaries. lf you want pictures of one being built l can do so. All of my headers come w/two 02 bungs & are high temp coated. Price would fall around $250. As for the turbo header, l'm prototyping 1 right now. l'm also building a tuned length alluminum sheet metal intake manifold. For those interested, l'm building an over the top engine for myself afterwhich l will have a line of forged pistons, A beam & H beam crome molly rods, over sized valves, HP springs, titanium retainers, high capacity oil pan w/windage tray, 200 psi head studs, main studs w/optional main girdle & aluminum sheet metal valve cover.
                              How about you take your own advice and
                              learn how to work on your own crap
