Had my festy over a year.ALWAYS runs perfect.Yesterday I started it in the morning and it knocked(not tapped) for a min and was fine within about 20 seconds.It is cold ,but,I have never had this happen.It ran fine.The oil was fine..any clues ???
Knocking for a minute
Could be a bunch of things. Imprtant to know is if it repeteats itself on another cold morning.
Could be fuel/ignition related pertaining to one cylinder. Sound should be like that of a diesel.
Could be low oil pressure...but that would be vlave tap like sounding.
Worst case would be piston slap....worn rings or loose wrist pin. Or, bad rod bearings. These conditions will produce a very distinct knocking sound that will be hard to locate, meaning the noise will trave the entire length ofthe cylinder. It is hard to determine if the orgin of the sound is top side or bottom side.
Keep an eye on the dip stick and for blue-ish smoke coming out of the tail pipe,Joe Lutz
The SKATE ..... 1992L 5spd
What weight oil are you using? If its to high of a viscosity it may be like honey in cold temps.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
and this would mean... what exactly? my car has been knocking for a while, and im guessing its a piston, but i have had some blue smoke before.Originally posted by jglutz View PostKeep an eye on the dip stick and for blue-ish smoke coming out of the tail pipe,
no thread jack intended.89 L, hopefully returning from the dead soon with a little more power... :twisted:
http://www.fordfestiva.com/forums/sh...77-my-89-build
92 integra, daily driver, broke a clutch disc, sold
New dd, 02 Nissan sentra, 1.8 5 spd
^^A loose fitting piston would create both a knock and blue-ish smoke.
Typically the upper or middle ring is shot.
A bad wrist pin or con rod bearings would make a lot of noise but not necessarily create blue-ish smoke.Joe Lutz
