Cause of the battery explosion...
  • Cause of the battery explosion...
    I finally got a used battery and a used radiator for Red after the battery explosion about 6 months ago.
    I hooked everything up and tried to start it. All it did was crank. The batteries charge got low so I hooked some jumper cables up to it and got a lot of sparks off the battery terminals. So that means I have a short somewhere!
    I looked all around in the engine compartment then I looked at the fuse box ..... Half the heater fuse was totally melted and disintegrated and it destroyed the part of the fuse box where the heater fuse was. I am also assuming the so called brain underneath the drivers seat is also fried!
    My questions are: *Could the fuse box be causing the short & caused the battery to explode?
    *Why would the heater fuse just disintegrate like that?
    *Would the brain be causing this whole mess?
    *I am assuming it will not start because of the fried fuse box or fried brain!?
    1993 Ford Festiva L blue 170,000 miles
    1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
    1995 Ford F150 XLT black 203,000 miles
    2002 Honda CRV silver 180,000 miles
    2003 Toyota Rav4 Sport black 94,000 miles
    2008 Sym Rv250 dark grey 30,000 miles. My scooter.
    1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
    Mike
    For S&G's I would pull the alternator and have it tested.
    Running around outside the asylum again with my tappy talky appy
      The brain under the driver's seat is for the automatic seatbelts. It has it's own 30A fuse in the dash fuse box.
      I have no clue how the heater fuse could have just disintegrated. That's odd. Post pictures!
      -Zack
        S&G's ?
        Mike
          ^^^Poops and giggles.
          In other words, just for the heck of it, check the alt.
          White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
          White '89 LX 5-speed, Aspire swapped, Weber carb
          1988 LX 5-speed
          ​​​1993 L 5-speed B8, E series, Aspire/Rio swapped
          Gone:
          1986 Chevrolet Sprint 1990 L Plus Auto
            Engines need three things to run
            FUEL
            COMPRESSION
            SPARK
            Have you pulled a plug wire and watched it as it cranked?
            If it has spark you have another issue if it doesn't ya needs to figure out why and fix it.
              and check your alt .If it was overcharging the battery which may boil the acid and make hydrogen gas that will blowup with a spark. Had a truck do that long ago, It was the voltage regulator.
              Donn
              ______________
              93 Blue rio/aspire swapped,B8,
                Precisely. If it is putting out too many volts, it can also melt fuses...
                  I will get the alt pulled and tested.
                  Thanks.
                  Mike
                    Which reminds me. When my alt went bad and fried fuses, it also fried my ecu. I wouldn't get spark. So if yours tests bad, replace then test for spark.
                      Alt is good.
                      Now I'm stumped, I guess the battery itself was bad. After it exploded, the car was still running. A couple of days later tried to start the car without a battery, it started at first then it wouldn't start.
                      I have been trying to start it now and it will not start. It has a good battery and alt. I checked for spark and I am not getting any. So I guess I need to check the ECU?
                      Mike
                        It started WITHOUT A BATTERY?!!!???!!! RESIDUAL ELECTRICITY IN THE WIRES???!!???!!!!
                          Lol
                          91 Festiva L "Erika" b3t swap on the way
                          06 Jeep Cherokee Overland
                          95 Aspire (sold)
                            The car was running at the time of explosion?
                            The fuse is melted.
                            Alternator checks out fine.
                            I have no idea why the battery would explode, but a fuse being melted like that is because something is drawing more power than the fuse can handle.
                            I would replace that fuse block and leave that fuse out. The battery can't force too much power through a fuse. Something has to be on the receiving end PULLING the power from the battery. I'm guessing you'll be looking for a new blower motor but that's just a guess. You'll have to get the car running and troubleshoot to see how many amps/volts are going through that circuit then find what is causing it.
                            On second thought, i bet the battery exploded when the fuse block melted and fused together some contacts that should never contact...
                            I might have a spare ecu for cheap if u need one.
                            2008 Kia Rio- new beater
                            1993 Festiva- Fiona, DD
                            1997 Aspire- Babyspire, DD
                            1994 Aspire - Project Kiazord
                            1994 Aspire- Crustyspire, RIP
                              LOL! Let me rephrase that. We were jumping it without a battery in the car.
                              Mike
