spring rate calculator
  • spring rate calculator
    Has anyone looked into this? I'm trying to figure out the best way of lowering my car, with 145# miata springs, and cutting coils crossed my mind, but I don't want to blindly start chopping off things I can't put back.
    I found this online calculator, but I don't know wether I should believe anything it says or not, has anyone else tried it? I'm going to measure some springs I have laying around tomorrow and see what it says, but if you want to give it a shot let me know what you think of it..
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
    messing around, here's some results from that calculator..
    2002 MT Kia Rio front springs
    .445" wire diameter
    4" OD
    7 active coils
    175# spring rate
    99-00 Racing Beat Mazda Miata Lowering Springs (pn54018)
    .460" Wire diameter
    4.25" OD
    6 active coils
    193# Spring Rate
    1994 Aspire Rear Spring
    .375 wire diameter
    3.9 OD
    7 active coils
    90# springs
      Just did another spring, a front aspire spring. This calculator is touchy, the measurements have to be exact for the wire diameter.
      .445" wire diameter
      4" OD
      7 active coils
      175# spring rate
      99-00 Racing Beat Mazda Miata Lowering Springs (pn54018 )
      .460" Wire diameter
      4.25" OD
      6 active coils
      193# Spring Rate
      1994 MTX Aspire Rear Spring
      .375 wire diameter
      3.9 OD
      7 active coils
      90# springs
      1997 ATX Aspire Front Spring
      .406 Wire Diameter
      4.125 OD
      7 active coils
      106# springs
        calculator looks accurate. Aspire springs are 110# front 90# rear, IIRC.
        Jim DeAngelis
          Adding a new spring to the list. I am hoping one day one of you peoples will attempt this too! This is a front festiva spring..
          .445" wire diameter
          4" OD
          7 active coils
          175# spring rate
          .460" Wire diameter
          4.25" OD
          6 active coils
          193# Spring Rate
          .375 wire diameter
          3.9 OD
          7 active coils
          90# springs
          .406 Wire Diameter
          4.125 OD
          7 active coils
          106# springs
          1993 MTX Ford Festiva Spring
          .402" Wire Diameter
          4.25" OD
          6 active coils
          107# Springs
          I don't know why the measurements came up so different from aspire to festiva, but they did, and it still came out close enough to assume they're pretty much the same spring. I also redid measurements on a 2001 Rio spring, it's basically the same as the 02 spring I was doing, but there's really 7 1/2 active coils so the spring rate is in the vicinity of 160-175# .....looking for other measurements from other members!
            I haven't measured a rear festy spring yet I guess? This is looking good tho, I bet the rear 5 door avella spring will come in around 130lbs and would be perfect for the rear end of a Festiva. The 150lb. Miata springs are definitely too stiff for a daily driver.
            Originally posted by F3BZ View Post
            the spring on the right is the rear spring for the 94 5 door pride. the one on the left is a stock 3 door festiva spring. all dimensions are the same except that the wire diameter for the 5 door spring is 1/2 mm larger in diameter (10mm). when plugged into a simple online spring rate calculator the 5 door spring is almost 25% higher force for each inch of compression. (97 lbs./in. vs 121 lbs./in.). part# KK153 28 011. $25.45. still available as of 10/2013.
