Quest for More Power and More Traction! BP+T + AWD Build Thread
  • Quest for More Power and More Traction! BP+T + AWD Build Thread
    Well I didn't want to start a thread before I was fully committed to the swap... Since I went from this:
    to this:
    I'm pretty sure I'm committed.
    I'll be using a Miata rear suspension assembly for the rear half of the AWD setup. I am putting 323 GTX guts into the Miata rear diff housing so I have the correct ratio.
    Miata rear suspension:
    Jacked up in place to see how everything lined up:
    Looks like it will line up pretty well to me, just have to get it all centered. I did have an issue with the upper control arm contacting the unibody rails so I had to devise a way to replace that section of the unibody and still have some strength in the back of the car there.
    After a few different ideas I came up with this:
    And I'll tie the two sides together like this:
    They are just set in place for now, I need to get a few welding magnet/right angle jigs so I can tack weld the frame assembly together.
    I am so glad I picked up a metal chop saw (abrasive blade).
    near perfect cuts every time... mmm... sure beats the hand cuts with a sawzall or an angle grinder like all the rest of my projects.
    More to come tomorrow!
    89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
    94 aspire 3 door Red -- Former BP, V6 KLDE swap underway! RIP... Rotted and Flooded out...
    2012 Mazda 2 Touring 5 Speed... It's Very, Very, Very green... Daily Driver
    1964 Barracuda 360 V8 Push Button 904 Auto, New Money Pit
    Facebook Me!
    wow! i like the plans and fitment looks better then i would have thought
    will be following
    93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
    RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
    RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
    RJ
      that things gonna need to go on a diet.
        Sub'd
          thats more like it, finaly someone doing some big work to a festiva
            the tubing I am using is 1" x 2" and not too thick of a wall. I will try and do a comparison of what I took out and what I put in weight wise.
            Facebook Me!
              I wish it was an aspire... but I could not find a clean enough candidate to build off of.
              Facebook Me!
                I like your style!!
                I would try to do a weight comparison, it's very time consuming and a huge junk pile builds up real fast...what I did is build it light but sturdy. Then weigh it when your done and compare it to the stock specs..
                Love the project & can't wait to see how it turns out.
                http://www.youtube.com/watch?v=s8SilV257aM
                1999 SVT Lightning #1212
                1993 tube chassis Festiva 351w (shooting for the 9s)
                1980 Maples jet boat 455 olds
                1991 Chevy custom one ton dually
                1988 Mustang N/A 385 w/doug nash 9.88@137 (sold)
                2001 GSXR-1000 turbo lowered & extended (sold)
                1988 S-10 468 BBC lowered & body dropped (sold)
                on & on
                  Finally, some pictures! haha
                  1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
                  Rocketchips!
                  Bolt-on Weber Carb Adapters!
                    Matt what does the GTXR2 tip the scales at?
                    Facebook Me!
                      You are beast. Good luck
                      91 Festiva BP Autocross/Track/Rallycross hopeful
                      14 C7 Z51
                        She sat at 2750 after the BPT and AWD. ~2400 to start
                        Rocketchips!
                          I thought you might be planning this! Sweeeet!
                          Miatas have "correct" ratio rear ends, although my understanding is that you can vary the ratio difference front/rear for different torque split. What tranny you going with? One with the viscous center diff?
                            wow looks like its will be a kool ride when done I LIKE IT
                            Don't meddle in the affairs of Dragons for you are crunchy an taste great with katsup!!!
                              Sub'd
