Finished the Intake manifold mods this weekend. The final finish on the runners and inside the plenum was provided by a 120 grit flapper wheel, followed by a 220 grit "buffer" pad. Almost mirror finish, although it's hard to tell by the pics. The entire runners on both upper and low manifold sections are finished, as well as areas inside of the plenum and right above the runner openings. I did the best I could on the back wall and floor of the plenum...it was pretty hard to access all the areas.
The ports were gasket matched between the two intake halves and the lower intake was gasket matched to the head as well.
I took some extra time to "restore" the plaque on top of the intake. It was pretty scratched up and pitted, and initially I was just going to remove it. I used some Maguires Ultimate Compound to polish it, then I used some black touch-up paint (left over from my Taurus) to touch up all the pitting marks and scratches. Finally, I masked it off and sprayed it with several coats of Duplicolor 500* Clear engine enamel to give it some shine and protect it. It came out really nice!
This week I should be able to start assembly of the short block...Yea!! :p
