G25MR 5th gear swap info
  • G25MR 5th gear swap info
    After some research and a trip to Pull A Part I have found another source for the illusive 5th gear. Pause for dramatic effect.... The non turbo MX-6. I also found out that it takes less than 20 minutes to acquire the gear from the donor trans. This swap is a simple fuel saver for the fastivas out there.
    Festiva/Mazda genetic splicing researcher B6T / G25MR for 5+ years and counting.
    187.7 WHP @ 5500 RPM
    SWEET! Sounds like this could be a good upgrade for my Turnpike Cruiser project :thumbright:
    If a hammer doesn't fix it you have an electrical problem
    WWZD
    Zulu Ministries
      I should do this swap one day :lol: 4k rpms @ 120 km/h (75 mph) really sucks lol
        ^^ WORD
        Wishin I had a tack cluster this day LOL
        WWZD
        Zulu Ministries
          I've had my speedo buried and it goes to 200km/h and I was revving at 6k rpm, but my redline is 7500rpm so I had room to go
            Mark did you run out of DrPepper?? Pinning the needle to the corner store.
              ^^ Dr. Pepper AND Marlboros! Gotta get to a Quickie Mart STAT!!!!
              I took that on the way do to the first SC meet when I was running a little behind schedule. The Escort 9500ix earned it's keep that day
              WWZD
              Zulu Ministries
                what year of non turbo mx-6? also what tranny is it they have?
                90 festiva BP/G25MR swap, spec v seats, aspire brakes, FMS springs, round headlight conversion with HID's, custom exhaust, fiberglass hood, and a whole lotta bodywork
                BEFORE AFTER
                  Did this ever get finished. I really want to do a 5 th gear swap just Ned to know what I am looking for.
                  the heart beat of america stops here______________/\
                  \/\_____________FORD
                  FOREVER
                    Well here's a writeup for the install (ignore the PG instructions. The 5th gear can be done in-car, at least I could in my Capri) http://www.clubprotege.com/forum/showthread.php?36485
                    From Page2 CrazyCanadian commented on the gear source:
                    G560-17-611B - Primary Shaft 5th gear
                    G514-17-308 - Secondary Shaft 5th gear
                    That should be the part numbers... Other wise its off the early FS 2.0L mx6/626..
                    I got one of my .717 5th gearsets from Clay "azgtx" on ClubProtege/TeamCapri, I think he gets $65 a set?
                    My other set I pulled from a 2g Probe GT transmission, apparently they're also .717 probably due to the short final drives
                    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
                    Rocketchips!
                    Bolt-on Weber Carb Adapters!
                      is there anyway to identify the .717 ratio? it is the biggest correct? are there any taller 4th gear options??
                        Count the teeth & divide the numbers, you get the ratio.
                        I don't know of anyone that's modded a 4th. That gets tricky because you have to disassemble the whole trans & press bearings off etc. The 5th is outside of the main transmission case which makes the swap easy
                        Rocketchips!
                          what do you divide the teeth by? so lets say i had 73 teeth what would i divide that by?
                            There are two gears that make up a "gear" in a transmission
                            Rocketchips!
                              +1 for Clay. I'll give him some reps here as words of encouragement. I purchased a VJ14-to-VJ11 swap kit and a set of brake calipers from him, and he was a fantastic seller. Highly recommended...
                              1988 Chevy Sprint Turbo 997cc
