I am puzzled by a noise my stock 94 Aspire with 81,000 miles makes.
So many times I have seen members post a question which included their own unfounded thoughts about what may be causing their problem. Then the discussion is dominated by reference to those questionable remarks. In trying to avoid a repeat of that process here, I'll limit my initial remarks to reporting how the recording was made and some remarks about what you will be able to confirm for yourself from the recording.
Of course, I've listened to this many times and thought a lot about what might be causing it, but, rather than prejudicing your minds with my own dubious speculations, I would ask you to just listen to the recording until you are able to imagine what parts of an engine could be capable of making such a sound at this particular rpm.
After members have had a chance to express themselves I'll return here with my own speculations, together with what I know of the history of the car, which may or may not be helpful.
The recording was made using an Olympus DS-30 digital recorder. While the owner of the recorder held it down close to the top of the engine, to avoid any wind noise, I manually operated the throttle to find the spot at which the noise is most pronounced. That seems to be about in the middle between the fast idle at cold startup (I would guess about 1200.) and the normal idle speed of 700. The noise is not noticeable at the extremes of that range when standing before the open hood. (The placement of the recorder so close to the engine brings out sounds that I did not hear as we made the recording. Like the faint whistle noise.)
In case your player reports playing progress in seconds, I'll identify some points at which the noise seems to reach its peak. Among those times are the ones at the following seconds: 2, 4, 6, 9, 11, 16, 26, 29, 32, 35, 43-44(This is the clearest example.), etc.
There is a certain rpm at which the noise is most pronounced. I was trying to find that point and stay at it but the engine was not responding to the throttle quickly enough and kept over and under shooting my efforts at control.
Here is the recording:
I look forward to your response.
John Gunn
Coronado, CA
John Gunn
Coronado, CA
  (Along with that last thought, do you have P/S, A/C or other belt driven accessories we should know about?)
