LED instrument cluster light mod
  • LED instrument cluster light mod
    I've had issues with the cluster lights on the right side of my cluster since it had 12K miles on the car. I saw an LEDstrip at Walmart that looked like it would fit the area that the bulbs fit into. They are 8", Blue and cost about 13.00 per pair. I hooked them (actually one of them) to the standard light connection so the dimmer still works. I'm running them on low (dimmed to the minimum).
    Attached is a link to the video I made last night. The quality is not to my standards but it will give you an idea of what is involved in the mod.
    The directory has 2 videos. 1 in the car of the dimming action, the other of the assembly of the cluster. I call it the BeBandit LED light/gauge cluster mod.
    It was debuted at Carolina Spring FestivaL Saturday night
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
    I bought those lights a while back with the same plans, and never got around to doing it. I'm glad it works that way though. Thanks for sharing.
    The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
    My Fleet:
      I may have to try this once my festy is up and runnin.
      Man should eat when he can for Man does not know when his last meal will be.
        I did this with green LED's about four months ago because My right side was out as well.
        88 Festy L (The White Thunder)
        91 L came and gone, owned only 2 days
          I just cant use to how dim they are. I am use to the newer gauge cluster lights being brighter.
            Its a night and day difference, I have mine on the lowest setting on the dimmer and its still pretty bright. It doesnt distract me at all though
              Nice! And a lot cheaper than buying LED bulbs bright enough. This one goes on my list . Did you keep the regular bulb behind the ODO?
              91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
              92 L 5sp "Red" RIP
              95 Grand Prix SE DD
              Wife's Stuff:
              89 L 5sp "Carby Car"
              97 Aspire auto "Pink Panther"
              Build Thread
              Spring 2013 IndyStiva:
              http://www.fordfestiva.com/forums/sh...eet-April-20th
                When I did mine I kept all the regular bulbs except the ones that shine from above
                :cry_smile: RIP. 91 Ford festiva BP swap
                1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
                  The only ones I replaced was the upper ones. Mine had 4. I now run it on full dim most of the time. I'm experimenting with some other things for appearance.
                  Jerry
                  Team Lightning
                  93 L Lightning. BP
                    VERY NICE. This will be on my to do list as well .
                    First time owner
                    89 L carb'd - white / still needs work
                    Bought for mpg and only paid $250
                      Navdoc, I think this is the thread you were looking for in the pm you sent. I'm on my phone at work so copy and paste of the link is difficult.
                      Jerry
                      Team Lightning
                      93 L Lightning. BP
                        I always liked the appearance of blue light in clusters. I'd just solder up some of my own blue LEDs, though.
                        1990 White L-Plus 5-speed rust-machine
                        Scrapped
                        1991 Blue L 5-speed
                        daily driver, intermittent project
                        1993 rustless wonder
                        A shell, awaiting suspension, brakes, and B6T
                          No link, could you try again please.? I have this one, thought there was another post.
                          If it don't fit, use a bigger hammer!
                          '93 Green L - ' Tiva
                            Think I may have commented in the "what have you done to your festy" thread.
                            Jerry
                            Team Lightning
                            93 L Lightning. BP
