SHifter sloppiness solved!! no austrailia nonsense
  • SHifter sloppiness solved!! no austrailia nonsense
    So decided once and for all to cure shift linkage problems found everything for about 25$ and here's all the part numbers below! There's 6 bushings 2 bolts and the solid main bushing with its sleeve as well
    bottom right 3 are the 6 bushings bottom left is the bolts top right is main sleeve and top left the main bushing
    hurry to your local mazda dealer!
    93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
    RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
    RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
    RJ
    Are these for one car or two? Could you please post the part numbers and amount needed for one car?
    I'm kinda getting sick of Aqua's shifter sloppiness. I sometimes put her in fourth when I want second!
      not to be rude but you should be able to read part numbers in pics i can let me know if you cant and yes this is for one car
      RJ
        ill add these to my list for the tank....thanks
        Don't meddle in the affairs of Dragons for you are crunchy an taste great with katsup!!!
          skim pretty please can you take a moment to get those part numbers and quantities? its hard to tell from the picture i can only read 2 of the part numbers and the other bags are all covered up.
            Alright everyone the next supply list is for one car
            1 - GJ21-46-041(solid linkage bushing)
            1- B092-46-047(solid linkage bushing sleeve)
            These are the bolts you don't need all three unless your anal !
            if not you'll only need 1!
            1-B001-46-133(bolts 1 or 3 if anal)
            3 - B001-46-062 (bushings in pairs)
            the bolts do not come with nuts just to note
            RJ
              Perfect, now if you ever delete or move that photo people will still be able to use the info you've provided. Thanks!
              Nancy- 1.8L BP, aspire swap, g-trans
              The Adventures of Nancy! Build Thread
              My Musica! Click me!
                Thanks Skim!
                  Yeah RJ wth ?
                    This is awesome.
                    Thanks!
                    Rodney
                    1991 FI 5 Speed Aqua Blue
                      Shifter
                      Thanks buddy!!:mrgreen:
                      If it don't fit, use a bigger hammer!
                      '93 Green L - ' Tiva
                        thanks for listing the numbers!! +1 to your rep
                        Walth
                        Festiva #1: 91 Red L 4/5
                        http://www.fordfestiva.com/forums/sh...ad.php?t=27981
                          Order assembly from Korea?
                          See Shifter Play Problem thread.
                          I had a reply from a member saying the entire assembly could be ordered from Korea.
                          Has a link to a Russian web site showing the assembly.
                          Anyone else hear about this?
                            I'm sure it's legit. BraveKozak is great at finding nifty rare stuff for sale. I haven't looked at it even, or to see what shipping is but keep in mind shipping is a good bit from out of the country.
                            Walth
                              Yes, I've ordered from them before. They're legitimate.
                              Go to: http://www.fourgreen.com/store/scripts/prodList.asp
                              Select: Hyundai/Kia
                              Type in: KKY01 46100B
                              Click on "Search" and you'll get the shifter assembly. Order away.....
                              88L - 'Twistiva' - 'The Fusion of Man and Machine'
                              88LX - 'Laztiza' - Future Resurrection Project
                              91L - 'Mistiva' - My Daughter's DD
                              93L - 'Vextiva' - Airport Car
