Hi - My Festy runs very warm even after a 15 min trip and always the fan is running by the time I stop. On long runs I have to reduce speed to around 70kph just to keep the temp needle out of the red.
I have removed the thermostat (which was not corroded at all), flushed the rad several times, checked the pump which seems ok and made sure air passes through the rad ok. The car has only 120,000 on the clock and is in good condition generally.
I am baffled by this am concerned that continual hot running will cause damage to seals or other expensive repair jobs. Does anyone know whether this is a common problem and if so what is a likely cure?
Many thanks
Kirk33
Many thanks
Kirk33
