Front Clip Replacement
  • Front Clip Replacement
    Now this is a daunting job!!
    The front end of Icetiva, a Festi with a B6T I ice race, folded up 'rite nicely on its second weekend of racing. Two cars spun in front of me on two occassions and that was the end of the driver's side frame rail, from just forward of the strut tower. The car has sat for two years now, and it is finally getting some drastic repairs. I never could get a good shot showing the magnitude of the damage, but the rails were too bent to ever make them pretty and straight again. in fact, I could not get angles on them to unfold them at all using hammers and pull chains. A frame shop wanted 14 hours on the frame machine to straighten it.
    Drastic surgery was suggested, so I went to Pic and Pull and chopped off a front end, then thawed off the snow in our foyer. My wife was pleased with the new decorations, of course. And then I set to work with Hiroki's able help. We guessed at the fit, cut the new piece a little over sized, then took the big step and cut the frame and shell on the car. Then we fine tuned the fit, trimming and grinding as needed. That was several days work.
    We measured the height above the ground on both sides (compensating for the jack stand height difference), the distance from front rail to trailing control arm mount bracket, the width of the front rail compared to other cars, and the diagonal across the engine bay from the two trailing control arm brackets. A few mounting holes and stamped metal holes were used to double check the position. The new part seemed a touch higher than it should be, but good in all other dimensions. We could not get the height identical on both sides and still retain all the other geometries. Spacers on the sway bar mount brackets will fix the height difference if we need to.
    Hiroki then set to work with his excellent welding skills, and started tacking it together. He did a fair amount of reading on how to weld the tissue paper they used for sheet metal on these cars, to avoid burn through. It is now tacked in place. Next he starts on the serious welding, fish plating and strengthening! That will be a few more days work yet.
    Thricetiva replaced Icetiva as the new ride
    Icetiva-3-race-car-build
    http://www.cardomain.com/ride/2533299
    good to see its not being given up on! keep up the good work!
    1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
    T3/T4 Turbo Power! G5MR and BP since '04!
      wish I could see the pics but it sounds like you put alot of work into it
      92 GL - parts car
      97 aspire - parts car
      87 323 DX - daily driver
        It'll be good to see the hard work pay off and have it running again!!
          Not sure what the pic problem is. If you double click the pic thumbnails they should open as large as life in ImageShack.
          So Hiroki got the welding done! He's certainly my hero. Here are some more pics of the bends.
          And here are some of the welds.
          And it seems it went together well. We got the wheels and sway bar on. And when we dropped the hood it fit right over both hood pins. Sweet!!!
          Now I just need an engine. That's next weekend.
            Nice work!
            -85' Nissan Sentra 5 spd.
              Think he is just at work or something and has to wait to see them
                Awesome work Jed! Kudos to Hiroki.
                By the way, Race City got an two year extension on their lease!
                Cheers
                Ian
