Check Engine Code List
  • Check Engine Code List
    Anyone know where I can find a list of code reasons? I saw posts on how to check codes, but not for meaning. I have a 89 Festiva, switched out the transmission but the neutral switch mounted on the transmission by gear selector is damaged. Car starts and operates great, but since the repair now the check engine light is on? Im guessing its because the computer isnt getting a signal from this switch...can anyone tell me if that is correct?
    What code are you getting?
    Have owned 9 so far
      I havent actually checked codes yet. Just found this site last night while trying to research possible reasons on net. At this point car was fine before, tore out bad transmission, put in new, accidentaly broke wire on neutral switch in process and now when I start car check eng light is on. I will check code tomorrow. Just seeing if anyone shared this experience.
        Assuming since you have an 89 with manual tranny that yours is carbed?
        From my Haynes Manual
        Carb Trouble Codes
        01- Ignition coil signal
        09- Coolant temperature sensor
        13- MAP sensor or circuit
        15- Oxygen Sensor Malfunction
        17-Feedback system
        18- Air bleed control valve #1
        19- Air bleed control valve #2
        20- Air bleed control valve #3
        21- Air bleed control valve #4
        22- Fuel shutoff solenoid/ circuit
        28- EGR vacuum solenoid
        29- EGR vacuum solenoid
        31- Air Control Valve solenoid
        34- Idle-up solenoid
        35- Idle-up solenoid
        38- EFE heater relay
        70- Vacuum switch
        EFI Trouble Codes
        01- Ignition Diagnostic Monitor (1990-1993)
        02- Crankshaft Position Sensor (1990-1993)
        03- Cylinder Identification Sensor (1990-1993)
        03- Camshaft Position Sensor (1994-later)
        04- Crankshaft Position Sensor (1994-later)
        06- Vehicle Speed Sensor
        08- Airflow sensor (1990-1993)
        08- Mass Air Flow Sensor (1994-later)
        09- Coolant Temp Sensor
        10- Intake Air Temperature Sensor
        12- Throttle Position Sensor
        14- Barometric Pressure Sensor
        15- Oxygen Sensor
        16- EGR Valve Position Sensor
        17- Oxygen Sensor
        25- Fuel Pressure Regulator Control Solenoid
        26- Solenoid Valve (purge control)
        28- EGR Control Solenoid (1994-later)
        29- IAC Solenoid (1994-later)
        34- IAC valve (1990-1993)
        Don't really see anything here that would pertain to the neutral switch.
        1988 L - 232K miles Batstiva
          I was just being lazy about typing the list! IIRC, it shows code 12 first, then any trouble codes, then 12 again to show end of stored code listing.
          Have owned 9 so far
            makin the festy tattle on itself
            what is the best way to "make the festy rat out its codes"
            And tell me this is easier than trying to get the stupid CV axle(s) out OR finding the HEATER MOTOR -OR- Trying to find out where the stupid O.B.D SENSOR IS!!!!!!!!!!!!!!!!!!!
            Better yet
            CAN SOMEONE WITH A DIGITAL CAMERA JUST GO SHOOT A PICTURE OF WHERE ALL THIS STUFF IS HIDDEN AND IDENTIFY IT
            YEESH
            Joe
            Go Ahead and Laugh .....Mines faster,more fuel efficient, ...AND PAID FOR!!!!!
            :sign3:
              analogue volt meter will do it. I think you can also just count flashes. It's expalined in the Haynes manual. Mine's at home an I'm at the public library.
                There is a single wire plug (STI connector)that is located near the wiper motor under the hood that needs to be grounded. If you have the "check" light on your cluster, it will flash the codes with the ignition switch on the on position. If you don't have a cluster equipped with the light, you use an analog volt meter and note the sweeps. The connection to the test meter is different color coded wires between FI and Carb cars(STO connector).
                Have owned 9 so far
                  The heater motor is under the dash, below the glove box. Page 3-8 in Haynes.
                  OBD-I info is on pages 6-5 to 6-8 in Haynes.
                  I have no experience with the stupid CV axle(s).
                    Correct. Connect the positive lead to the STI connector, ground the negative lead. Count the number of times the needle jumps. The first number will be slow jumps/flashes, the second number will be fast. EG, if it's throwing code 34, you'll have 3 slow jumps and 4 fast ones.
                      Getting a Code 9
                      Hooked up the jumper wire today and am getting code 09. Coolant sensor? anyone have prior experience with this? Where can I get a sensor, wiring looked ok, guess just replace it???
                        It is located on the back side of the engine, under the intake manifold. You may want to check out that connector. It has a fine wire bail that locks it on the sensor. Maybe it is not making good contact. If you need one, they run about 15.00 at most part stores.
                        Have owned 9 so far
                          Picked up and replaced coolant sensor....however unfortunately no change in the code. I unhooked the battery and stepped on brake pedal for 5 sec to clear codes, but check eng light immediately comes back on. Reran wire and its blinking out 9 again. Im guessing its a wiring issue. I tried spraying some electrical cleaner on the connection at the sensor but again no change. Anyone have any ideas or good methods to continue the troubleshooting? Thanks. PS My temp guage doesnt move at all. I'm assuming that the coolant sensor on the back of the motor that I just replaced sends the signal for this? Or is there some other component/sensor etc that could also be bad giving the 9 code and not giving a temp reading?
                            The gauge is hooked up to the sending unit on the front drivers side of the head, yellow/white stripe wire. The next step is to see if you have 5 volts going out of the brown/red at the sensor to the computer(ECA), if it is less than 5 volts, look for a short in that wire. The next step is to look for a break or short out the other side to the MAP sensor mounted on the firewall next to the three solenoid vales that have vaccum connections that you see attach to the air cleaner. Next is to test the Black/White terminal connection at the MAP to see if you have 12 volts.If not, look for an open circuit to ignition switch. The next steps have you checking all the other wiring from the connectors on the MAP back to the ECA for breaks. Other than those checks, it takes you to a check of the "Main" (center) fuse link wire circuit that distributes power from the block on the drivers side strut tower into the ignition switch, and on to the ECA down the white wire circuit through the "interior" fuse in the fuse panel under the dash.
                            This is the troubleshooting procedure from the shop manual.
                            HTH
                            Michael
                            Have owned 9 so far
                              Does anyone know what the orange/blue wire is for that comes up by the distributor? On my 89 it is just unplugged and I cant find another connector anywhere to plug it into?
