Where can i buy longer lug bolts and wheels spacers for this thing? What is the bolt size/pattern and what do I need to run a 1/4 rear wheel spacer?
Lug Bolts/Sources
try BMW or VW lugnuts... then if they don't work, you'll have to order aftermarket.Trees aren't kind to me...
I got my studs & lugnuts as a set from C2 Motorsports (aka C2 Racers) in San Diego.
I got the ones I used on Batstiva with the 14" wheels from Carquest. We kind of had to dig through all their catalogs to find them, but they ended up being 1/2 longer than original, but looked original.
1988 L - 232K miles BatstivaDumb thieves go to prison, smart ones go to work for the Government.
another aftermarket source:
X2 these are great guys highly reccommend them.
Their phone number is 1-858-495-9200
Ask for Steve or Ron Steve is usually the guy that answers the phone.
Good luck.
- Conor
Originally posted by sam.1956 View PostI got my studs & lugnuts as a set from C2 Motorsports (aka C2 Racers) in San Diego.
http://www.c2racers.com/servlet/the-...uts/Categories
I learned something. Thanks .Originally posted by perucho View PostYeah, the older mercedes lug bolts for alloy wheels are longer and you also get an upgrade from the stock 14mm to 17mm. Definitely a junkyard item.
