Been lookin' around, but I can't find any specifics on the Aspire swap. Everything's pretty much the same? Unbolt from the Aspire, bolt right on to the Festiva? Seems to be what everyone's saying, but I just thought I'd ask.
Aspire conversion
Aspire conversion
Tags: None
Basically, that's it. You need the front spindles, rotors, calipers, the whole rear axle beam (with brakes) and the e-brake cable. Then, just remove and replace.Festiva: Because even my dog can build a Honda.
Whenever this question pops up I always offer this how-to....I didn't write it, but it's what I used when I did mine. Great help!
"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Gone but never forgotten, "Hulkstiva"...http://www.fordfestiva.com/forums/sh...ht=progression
You pretty much just have to go to the junkyard and dig in! I didn't know what half of the how-to was talking about because I had no idea what all the different brake components were called. I printed the how-to out, took it to the junkyard, and just started tearing an aspire apart!! It's actually pretty easy"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
You also need the tie-rods (you can use escort or 323 ones too) and the flex lines are slightly different, one the little hook part where it bolts to the caliper, but that can be bent to be made to work
Finally finished up my front end including the aspire swap and my alignment is WAY off. Is that normal? I did the aspire swap, aspire sway bar, new axles, tie rod ends and new control arms."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
^did you use aspire or festiva LCA's? also did you use aspire or festiva tie rod ends?
Festiva LCA's with Escort tie rod endsOriginally posted by sasquatch View Post^did you use aspire or festiva LCA's? also did you use aspire or festiva tie rod ends?
Thanks for the help Will. Gonna try to get it fixed now!Originally posted by Motoxpress View PostGive a call Cody I need to ask some questions before I try to diagnose your alignment woes.
Will"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Probably when you put the tie rods on that messed up the alignment, just a guess thoughOriginally posted by lanemeyer14 View PostFestiva LCA's with Escort tie rod ends
when you do the swap do you need to use the aspire struts and springs for the front and the back? the festiva has just shocks in the back right do the aspires? iv never looked at one haha dont like themLast edited by hofficergrover; 08-04-2009, 07:18 PM.
use the festiva suspension front and rear, they bolt right upOriginally posted by hofficergrover View Postwhen you do the swap do you need to use the aspire struts and springs for the front and the back? the festiva has just shocks in the back right do the aspires? iv never looked at one haha dont like them
