Hi i want to swap out the front bearings on my 89 festiva but reading thru the posts i have a few questions..
1. when removing the rotor to remove the wheel bearings do i simply remove the caliper or are their any other components to remove.
2. are both the inner and outer bearings on the rotor.
3. after removing bearings and cleaning and turning the rotor can i freeze the bearings to shrink them and heat the rotor to expand it so the bearings will slip in.
4. do i have to grease the bearings first making question 3 unlikely.
I want to know if this is all worth it or should i just take it to my mechanic which quoted me 160.00 for each side that includes parts, labor and turning of the rotors....
