This was submitted by Qaking,
Hot at all times - WHT/RED
Hot in run or ACC - BLU/YEL
Interior lights - BLU/WHT & RED/BLK
Left rear speaker - GRN & GRN/WHT
Left front speaker - BLU/ORG & BLU/RED
Right rear speaker - GRN/YEL & GRN/RED
Right front speaker - BLU/BLK & BLU/WHT
Ground - BLK
I have not researched this yet, But, I believe it to be true. The only thing that I don't feel is accurate is the Ground. On my 89 L there was no black wire, I had to make my own ground. Make sure that you check the fuses after you install the head-unit if it does not power up, then check your ground. If all else fails, remember, a good digital Multimeter is your best friend.
Eric
Ground - BLK
Eric
