Pic request.
  • Pic request.
    Dose anyone have an evap case they can take pictures of for me? I'm trying to determine if it would be feasible to install a heater core in one. We didn't get a/c up here.
    89SX funtop! Fully loaded!
    RIP 90LX
    I have many of em, but I am not home at moment but sure I can show you pics once I return to my home tonight.
      Here you go,
      I am sure it could work fine but, I wouldn't want give up my A/C for hot summer.
        Sweet! Thanks! :p That looks more promising than I thought! I can make it thru the summer up here without a/c (not that I have a/c now anyways). But the winter.. now thats another story... I can't take the cold.
        With a heater core in there on a solenoid valve I could have.. DASH HEAT!!! woo-hoo! This is looking good. That and a big factory a/c blower motor, I could be the festiva heat king! :laughing6:
        RIP 90LX
          crafty devil....
            Originally posted by sasquatch View Post
            crafty devil....
            :evil4: :evil3:
            RIP 90LX
              that is an awesome idea!! if your sucessful post how to pics, i'm sure many of us here (myself included) would like to do this
                So do you plan on T'ing off of the hoses from the original heater core hoses to the secondary one? And then from the box hooking up another blower motor with ducting to the dash vents?
                Sounds like a great idea! Write up!
                  Will do! Just have to find an evap case!
                  Kinda. I will Tee off the coolant lines from the original heater core. And I will install solenoid valves in the lines so it can be shut off in the summer.
                  But, no additional ducting will be required. With AC, the evaporator is installed 'in-line' with the heater/blower case. The box FestivaGTX pictured gets installed between the air intake and the heater/blower case, so all the air for the climate control gets sucked through it. This is how A/C can be blown thru the dash vents. What I'm thinking is, getting one of those cases, and instead of having the A/C evaporator in there, Im going to put a second heater core in there. So all the air for the climate control will be heated! And even better... when set on defrost/floor the air will pass through two heater cores!!!! EXTREME!!!!
                  If there is enough room I am going to use a stand-alone heating unit from princess auto. They sell these 'auxillary heaters' that are an all in one heater core and blower motor, some of them are pretty small. They range from about 3,500 to 36,000 BTUs
                  RIP 90LX
