aspire brakes at/mt?
  • aspire brakes at/mt?
    seen alot of sites for parts and they always say specify mt/at? if you get the matching pads for the rotors will there still be a problem? or is there actually a different caliper's for at to mt?
    93-1.6l
    f.s.- fms bodykit.
    IIRC everything is different between the two except for the knuckle
      For the auto: The caliper is wider, the disk is wider.
        man they get you every which way. better double check if the donor is at/mt then.
        93-1.6l
        f.s.- fms bodykit.
          wonder if they'll let me work on my car in my B'ham apartment parking lot?
          Wow, I got parts off a '97 Aspire April of '07 and swapped the rear axle to my '91 Festiva L 5 speed, but haven't gotten around to doing the front end yet AND HAVE NO IDEA WHETHER OR NOT THE ASPIRE WAS A MANUAL OR AUTOMATIC?
          Is there anyway to figure this out, for my future reference?
          All I have is a crate full of the Aspire front end parts; steering knuckles, rotors, calipers, tie-rod ends, etc.
          '91 Festiva L/'73 Windsor Carrera Sport custom
          (aka "Jazz Bobstad," "The BobWhan," etc.)
          Art is the means whereby(a) society advances: Religion is the definition of the parameters of art. Poetry is the actualization of these...
            Good question, I recently went through the same thing. Bought the Aspire parts and did not notice if the donor was auto or manual, after staring at parts for a long time I noticed that the automatic transmission cars had a small 7th hole in the rotor aside from the two mounting screw holes and the 4 lug nut holes. If you have 6 holes in your rotor then you have the MT, if you have 7 holes then you have the AT.
            BTW, the brake pads are the same for either version.
            Good luck!
            I'm going to come at you like a spider monkey!
            White 1993 L plus, 5 speed - 47k miles
            * Aspire brake swap, 14" Miata wheels & Tein coliover suspension
              I can get you a measurement on the auto calipers if needed. I think b8kedbeans spelled it out.
                There are the four lug bolt holes, two big phillips head screws, and one small hole about 1/4" diameter; between a lug bolt hole and one of the phillips head screws.
                Guess I have the A/T front end?
                Last edited by bobstad; 10-08-2008, 01:10 AM. Reason: clarity of expression(removed one superfluous word, "two" between "the" and "phillips head screws."
                  good info guys thanks.
                  93-1.6l
                  f.s.- fms bodykit.
                    Check the large number cast into the top of the calipers. If I remember right the Auto's had a 22 and the manual had an 18 or 20.
                    Previous owner of a '89 Graphite L, 4spd, GL Seats, Aspire Brakes, 14x6's, 185/60/14's
                      I'm pretty sure the only differences are these:
                      Auto rotors are thicker.
                      Auto uses wider spaced caliper mounts.
                      Calipers should be the same, but most folks don't separate them from the mounts.
                      Pads are the same. Same pads as '91-'96 Escorts I believe.
                      Hardware is the same.
                      Your rear axle doesn't matter. It has nothing to do with the front brakes. All rear axles were the same between autos and manuals, two and four doors, as far as anyone knows.
                      (Some Aspires had ABS, but I'm not sure of those differences. I've never seen one.)
