a wee bit of Fuel Injector Info
  • a wee bit of Fuel Injector Info
    I've been looking into some injector info lately, and I came up with some info I thought may be useful to others as well.
    Make/Model..............engine............NipponDenso#. .......flow rate .....Resistance....color
    Ford Festiva.........1.3L sohc 8v B3...195500-2110 ........120 cc/min.....13.9 ohms ....purple
    Mazda 323...........1.6L sohc 8v B6...195500-1670 ........130 cc/min.....12.7 ohms ....green
    Protege/Escort.....1.8L dohc 16v BP..195500-2180 ........230 cc/min.....13.9 ohms ....beige
    Mercury Capri XR2.1.6L dohc 16v B6T.195500-1300 .......300 cc/min.....13.9 ohms ....dark blue
    to convert cc/min to lbs/hr divide by 10.5 (i.e. (120cc/min)/10.5 = 11.43 lb/hr)
    Note: these flow rates are based on manufactured recommended fuel pressure rates, which for the festiva (and I believe all of the others listed above) is 37psi (~250 kPa), but for a lot of vehicles it is 43.5psi (~300kPa). If you run a festiva injector @ 300 kPa instead of 250 you should flow aprox 130 cc/min instead of the 120 cc/min. Keep this in mind if shopping for other OEM injectors, you may have to adjust for fuel pressure differences.
    good sites for more info:
    list of lotsa injectors (no flow info):
    https://www.fuelinjector.citymaker.c...INJECTORS.html
    WitchHunter injector calculator:
    Injector Dimensions (stock festiva/323):
    I took measurements of an extra stock fesiva injector I had and modified the #'s on this drawing I found online... as a result the measurements may be off a little, but I think their pretty accurate. Please verify before you spend a couple hundred bucks on injectors that won't fit!
    To be updated as new/better info is found.
    ~Nate
    FOTY 2008 winner!
    what are the 16v sohc b8-me injectors? two of mine are smashed and i need to know how close they are to bp injectors, in case i want to modify compression and stuff
    1993 GL 5 speed
      BPT GTX Injectors 330cc
      89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
      94 aspire 3 door Red -- Former BP, V6 KLDE swap underway! RIP... Rotted and Flooded out...
      2012 Mazda 2 Touring 5 Speed... It's Very, Very, Very green... Daily Driver
      1964 Barracuda 360 V8 Push Button 904 Auto, New Money Pit
      Facebook Me!
        Between 155/170cc
