2B1 Headlight Conversion
  • 2B1 Headlight Conversion
    It's looks like the headlight conversion is going to be pretty easy. The guy from whom I bought 'Festus' included the necessary pieces for this conversion.
    The headlights are from a 1991 Aerostar. The buckets drop into the existing Festiva holes. The left light has to be used on the right side, because the adjuster holes are in board on the Festiva. 2B1 headlights are not 'side specific'.
    The replacements cost about $10.00 for the Halogens, and you get a new glass lense every time! They don't let water in either.
    The conversion's not done. I'm taking pictures as I go.
    '88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
    '92 Geo Metro XFi
    '87 Suzuki Samurai
    '85 F150, modded 300cid
    One more pic for now.
    '92 Geo Metro XFi
    '87 Suzuki Samurai
      by 2B1, do you mean a standard 6054 lamp?
      Jim DeAngelis
        looks like it to me
          me as well, that's why I asked.
          Jim DeAngelis
            hmm will the markers and grill go back on correctly?
            92 GL - parts car
            97 aspire - parts car
            87 323 DX - daily driver
              I think that's the replacement part number. The lights all have '2B1' cast into the glass, that's why I've been referring to them as 2B1. IIRC, the replacement Halogens are 6054H. I'll verify this next time I'm at Walmart. If this is accurate we could edit the title to the post to say 6054.
              '92 Geo Metro XFi
              '87 Suzuki Samurai
                Negative on the grill. I'll be fabbing a 'nose cap' out of 16 guage sheet metal. I'm going to remove the existing sheet metal trim you see below the lights in the picture.
                I may use the original side marker lights, I haven't decided.
                '92 Geo Metro XFi
                '87 Suzuki Samurai
                  Just curious here, but why are you doing this conversion? they don't look too much different than the stock ones
                    Originally posted by BigElCat View Post
                    I
                    Looking good. To be clear, are you saying you need two left side Aerostar buckets?
                    Thanks CZ
                      Gotcha. The 2B1 you're referring to is the code for the lens. Different countries use different focal lenses on the same lamp. 6054 is the standard number for that size lamp. The 'H' represents halogen.
                      Jim DeAngelis
                        The buckets are a pair that came out of an Aerostar. One right, one left. When installed on the Festiva, the left bucket goes in the right side hole. The right bucket goes in the left side. They just happen to fit this way, and it appears that they will adjust okay.
                        The Aerostar had the vertical adjustment screw toward the outside of the vehicle on each side. The Festiva has existing holes for the vertical adjustment screw toward the center of the car.
                        I'll take some more pictures as I go.
                        '92 Geo Metro XFi
                        '87 Suzuki Samurai
                          They're going to look like they were meant to be there. My reasons are:
                          1) The car came with no headlights or grill, I need to do something.
                          2) The local junkyard did not any good Festiva headlights, and they're rather expensive to buy, up to $100 each new.
                          3) The left front corner on this car is pushed back above the bumper, the original headlight would require much more extensive bodywork to be fitted than what I'm doing.
                          4) It's not costing me any money!
                          '92 Geo Metro XFi
                          '87 Suzuki Samurai
                            and those are all great reasons!!! Another great reason? Because you can!!!!
                            Jim DeAngelis
                              2 very good reasons right there :lol:
