^ Are they balanced? If they are balanced front the center of the hub (which is very common), you'll need hubcentric rings.
13" alloys
No hubcentric rings on mine, stock lugbolts, I get the lugbolts snug while the wheel/tire is off the ground, then tighten it all the way once it's back on the ground. I didn't notice any shakes while driving it, I've only drove mine out on the hwy a few times so far since It's not inspected/insured yet, but it drove great.Originally posted by Safety Guy View PostHow do you guys who have Honda VX wheels mount them?
Do you use hubcentric rings?
Do you use the stock lugbolts?
Any particular method of accurate mounting to avoid the shakes?
Karl-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
No need for hub-centric rings. On some aftermarket aluminum wheels, you will need longer lug bolts, or convert over to studs and lug nuts. The stock lug bolts don't have a deep conical surface, which is what is needed to seat the wheel properly on many alum. wheels.Originally posted by Amos View PostHrrm I don't know what hubcentric rings are... but they've been suggested to me in the past..
I'll look into them.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I have heard (but not tried yet) that if you use Aspire rear struts on a Festiva you don't need a spacer, due to the higher spring perch on the Aspire strut.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
That's my experience with Aspire rear shocks as well.
As for centerbore and hubcentric rings, Hondas are 56.1mm in diameter and Mazda Miatas, '91+ Escorts and Aspires are 54.1mm.
I found this site and plugged in some info, using "Escort" as my car:
Motorsport Tech is your absolute number one source for wheel adapters, wheel spacers, and hub centric rings. We manufacture the finest adapters in the world, and we do wheel polishing, chroming, powder coating, and color matching, as well as sell wheels and tires at WHOLESALE PRICES.
They want $100 for the rings and 15 for shipping.
Ouch. Of course, I paid a local machine company about that for steel rings for my VW alloys on Muttstiva after the suspension swap.
Hmmm.
KarlLast edited by Safety Guy; 11-27-2009, 12:25 PM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
Finally got this to upload. The Divas, (on the red car) are 114.5, the Incidents, and Theorys are 114.5 and 100 dual bolt pattern. All very light, all very strong wheels. I have put them to the test. I am sold on Konig making a good wheel at a reasonable price.
I had to use Aspire rear struts with stock height while using 175/70/13. That is what is on the blue car in the picture.
MichaelLast edited by m715; 11-27-2009, 06:26 PM.Have owned 9 so far
I have seen some 13" alloys from a Hyundai Accent that I like the looks of- kind of swirled. But I have not tried them at all. Hey guys, what size 13" tire do you use to keep from messing up your speedometer real bad? I know the OE Festiva 12" rim and tire is about 21.1" tall, I could not find a 13" that would be real close to that.186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
I wish I had the money to pick these up for my set of slicks.Current cars:
1993 Ford Festiva 5-Speed - Festiclese III - Cousin of the Banhammer - "The Jalopnik Car"
1984 Toyota Cressida - 2JZGE Swap, Turbocharged.
2013 Mazda Mazda2 - Exhaust and Wheels (the daily)
2002 Toyota Tundra - V6/Auto/2WD - The Tow Vehicle.
Some Esteems came with Speedline alloys.Originally posted by BUSTIVA View Post
I saw a Suzuki esteem 95ish I guess, had some really nice looking 13" oem alloys, but can't seem to find them anywhere now. Looked like these....
Like in this pic.
Maybe they used some other style of Speedlines on another year...
