So I just spent the past 6 weeks slowly and meticulously (mostly slowly) resealing and cleaning off the engine in my Festiva. I replaced the valve cover, cam and front main seals, oil pump seal, pan gasket, and dizzy o-ring. Looks like the thing is either still slinging oil from the crank, meaning that the crank sealing journal is so worn that I would have to sleeve it in order to fix it, or there is a leak somewhere above the water pump on the front side of the engine.
The water pump has been replaced by someone other than a professional, based on the gobs of RTV. Is there a place in that procedure somewhere that leaks oil if not sealed properly?
I'm looking at a new engine or a rebuild here on just 208,000 miles. It's kind of annoying.
