Can anyone tell me what are the correct tyre pressures for front and rear on the stock tyres from the car label because mine is not readable?
Correct tyre pressures.
According to the sticker on my door jam, here's the specs.
For 145/12 (front and rear) 32 psi
For 165/70/R12s (front and rear) 29 psi
Can't get either size here, only option for 12" tires is 155/R12s which I generally run at around 30-31 psi.
1988 L - 232K miles BatstivaDumb thieves go to prison, smart ones go to work for the Government.
You can get 1 tire:Originally posted by batstiva View PostCan't get either size here, only option for 12" tires is 155/R12s which I generally run at around 30-31 psi.
Originally posted by Pu241 View Post
Hmm, did not know that. But I was more referring to what's kept in stock locally around here. 155/R12 is pretty much it.
Seems the manufacturer changes quite a bit, but the size never does.
Yeah, got to be quick at Tire Rack, they seem to be out of stock very quickly.Originally posted by batstiva View PostHmm, did not know that. But I was more referring to what's kept in stock locally around here. 155/R12 is pretty much it.
Also expect with the new tariff on Chinese tires for the 155's to get more expensive.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Trade off between comfort and maximum MPG.
32 psi = comfort
44 psi = maximum MPG (and occasional blood in urine)'93 Blue 5spd 230K(down for clutch and overall maintanence)
I was under the assumption you put in whatever the tire itself calls for... I may be wrong, but I don't know why else a tire would have a psi rating if it didn't matter...?The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Originally posted by doylerl View PostI was under the assumption you put in whatever the tire itself calls for... I may be wrong, but I don't know why else a tire would have a psi rating if it didn't matter...?
You are wrong. You go by what the car manufacturer says.
1993 Festiva L, aspire swapped, selling parts for a BP+T build.
The tyre pressure rating is only the maximum pressure of that specific tyre can hold. If the car factory tells you it's 29 psi, then 29 psi it is. but if you wish to load that tyre with weight that 29 psi is too low you can inflate it up to the maximum tyre pressure recommended on the tyre.Last edited by lancerevo; 09-28-2009, 03:08 PM.:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
That is good information to know... I had never heard that before... Thanks for the information.
My Fleet:
When I worked at the shop I worked at we inflated most cars to 35 psi. I find the door jam pressures to be too low for my liking. I usually run max sidewall because Im stingy about saving gas and also like a firmer sidewall. Havent really noticed any uneven wear from it either. A bit harsher ride but Ill deal.91GL BP/F3A with boost
