Well, I know it can be done. I have seen pics of the one Stevo made. But there were no instructions on how he built it.
I have a couple in front of me and here's how I see it.
There is one layer of 12 spring steel tines. On top of that is another spring steel ring. If you remove that top ring and replace it with another set of tines, you should increase the clamping pressure.
By looking at the pressure plates they have 3 pins holding the clutch plate to the housing and the housing has been bent over both layers of spring steel on each side of the tines to hold the 2 layers to the housing.
Anyone stop me if I'm wrong, but if I could grind down the pins holding the clutch plate and remove it, then bend back the 12 housing clamps, replace the upper ring layer with another set of tines, bend the housing clamps back, tack the 3 pins back and viola??
This would be free to me vs. a perfomance pp that would cost $$$.
Comments??
Comments??
