I bought my festy in the summer of 08' at an auction. I brought it home, put in a new battery, new spark plugs, new wires, new fuel filter, oil and filter, air filter and sprayed a little WD40 down into the cylinders to lube up the piston rings that could have been sitting for who knows how long. It was obvious the car hadn't been driven in ages.
Well, I put my freshly made key in the ignition and vrooom, she started right up. It looks like there was a bit of a leak from the valve cover and I could hear a slight tick from somewhere in the engine, but overall she ran well. I drove her around the block and up to the gas station a couple of times and then parked her and returned to school.
I've been collecting parts ever since.
Last February I had to move it up to my fathers house and returned home for the weekend to do it. I figured the battery was dead so I tried jump starting the car off my DD, but it would not fire. It seemed to want to for just a second at first, but then nothing. Perhaps it was trying to start on fumes, but the engine never actually turned over.
After working for a couple hours in the rain I found that when the key was turned, no fuel came out of the fuel line before the fuel filter. So I figured the pump was bad, bolted everything back together and pushed it on the trailer instead of driving it to St. Joe.
Now fast forward to today, the Festy is being brought down to me here in Louisiana and I am finally ready to start working on it. The first thing I must address is this no start issue.
SO, do you all think it could be the fuel pump or something else?
Where could I look for a good used one? Any other cars by Mazda or Ford that I could source one from? There are several junk yards around here I could look through.
Also, I'm planning on a built BP swap, should I just spring for a 255lph fuel pump off ebay? Has anybody had any luck with these?
I know its alot of questions but I'd appreciate ya'lls input! Thanks!
