110mph issues
  • 110mph issues
    Anyone have a pic of what works for the 110mph speedo. All the little screws dont line up right on mine.
    Pic's up in a sec.
    It's a good thing you don't read the stickies, you might of learned something.Poverty produces creativity
    110mph
    Whitefaced USDM 85mph
      Only 2 screws are used on the 110mph for the tach. Its got a much larger circuit board. The old 85 uses 3 in a line.
        Well I cant just swap the tach damn.
          What the euro does for a tach signal
          The board I have to make work.
          The pink are where the euro tach signal & ground come through on the USDM J38R board.
            Its definetly different than the 110 board that came on mine.
              Grrr thats what I was thinking. Anyone have a pic of what theirs looks like.
                I checked my spare 110, its different than your too! Why not just put the speedo and face in your 85 mph unit.
                  Yeah.. mine is different as well.. sucks to be the guinea pig. What year is everyones 110mph cluster?
                  Mine is a 98.
                    "IF" :crybaby: you guys could remove yours & take a pic we could compile them into posibly a sticky. Oh well drill & solder here I come. :protest:
                      I have the 98 board in front of me now.. want me to post a pic?
                        sure cause my idea doesn't let the car start. I think I swaped the tach signal with ground.
                          Just put the speedo unit and faceplate from the 110 into the 85 MPH unit.
                            Then I wont know how fast I'm going. Its graded differently. Anyways it works fine I just have to figure out the TACH
                              Why wouldn't it work? If you use the speedo drive part (the thing the needle is attached to and the faceplate. Put both those parts into your old unit it will be a 110 and read correct.
