Center Armrest
  • Center Armrest
    I remember a few years ago, there was discussion of either sourcing or fabricating a front seat center armrest that would fit in the opening for the rear ash tray in the Festiva center console. Does anybody know if someone has come up with something along these lines? I thought I'd ask before I try to source an ash tray to experiment on with some hardware store bits and junkyard armrests.
    While we're on the subject, has anyone attempted a seat mounted armrest, maybe sourcing one from a third or fourth generation Chrysler minivan?
    Axlander9289, brother of ThisVelologist
    Festivas past:
    Aqua '92 Festiva L - Sold "Dale"
    White '89 Festiva L Plus - RIP "Dudley"
    White '93 Festiva GL - Sold to thisvelologist "Frito"
    Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
    Current Fleet:
    Aqua '93 Festiva L with Aspire brakes "Dale Jr."
    Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
    White '15 Ford Transit Connect
      I have the mounts fabricated for my black leather Kamei armrest. I intend to weld it in the springtime. I like the fact that it pivots upward out of the way.
        Because of my previous response, I looked at how to mount it again. I have decided not to weld on some 1/2" sleeves onto the bottom of the '93 floor brackets. The angle would have been too great + I would have needed to bend a much longer rod. I have decided to cut off the existing VW Golf mounting tabs and mount a couple of flat flanges under both seat foot studs. If there isn't enough stiffness, then I will add the two 1/2" I.D. tubular sleeves, beside the seat foot studs. The goal is to straddle the console in between the seats while allowing access to the rear ash tray.
          I would use GM or Ford Minivan center seats if I wanted to replace the front seats
          Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
          Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
          Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
          it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
          Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
          TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
          bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
          '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
          SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
          R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
          R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
          R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
          R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
          R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
            I disassembled the VW Kamei armrest tonight. I cut off the secondary rod mounting tabs with a Sawzall. I heated up the primary mounting plate mounts with an acetylene torch and bent them outward ninety degrees. My next step is to determine if I have enough material to drill mounting holes or cut off the existing footplates and weld on new ones. Off to the Festiva... (to be continued).
              Test fit with the armrest feet shaped to fit the seat studs.
              The VW armrest is not level yet. It angles downward.
              It will have to be rewelded, since the internal adjustment screws cannot make up for that much slope.
                That is basically brilliant.
                  I was wrong. The adjusting screw easily levels the armrest. I had to turn it in about a quarter inch with an Allen key. When I get a chance, I will reinstall the armrest and post photos with the leather armrest cover in place and level. I had to remove the spring loaded change dispenser from underneath to make room for the future drink holder and repaint the legs where I burnt the paint with the torch
                    Did it come out of another car or did you fabricate that yourself?
                      I bought my used VW Kamei armrest on eBay Germany.
                      You just have to modify or weld a couple of mounting tabs on the bottom like I did.
                        I see! Thanks! Any time I'm on a road trip I think I want a center arm rest.
                        Sent from my C6730 using Tapatalk
                          scitzz, Kamei also has an armrest available with a refrigerated beverage compartment, just in case you get thirsty on a summer road trip.
                            HA! I might get too tempted to keep adult beverages in there!
                              Here's Johnny!
                              I wish there was a drink holder with the contact surface surrounding the bottle vertically. I wonder if they use the same thermoelectric refigeration as the Koolatrons?
