Hole in metal coolant line now....
  • Hole in metal coolant line now....
    I posted this in my existing post but I wanted to make sure folks see it so I can possibly get some help with this. I was wanting to burp the coolant system and I started to pour in the antifreeze when I hear a steady stream hitting the ground. In the picture is where the hole is, right on the bottom of the smaller tube right before it goes into the flared end.
    I was thinking I could possible cut the section before the hole and the section after the flared part and get a piece of tubing of some sort and clamping it on both ends. Would this possibly work? What type of tube should I buy to try this? Thanks for any help. Jim
    If it is a hole, that is awful close to the connection. I just saw one yesterday that somebody repaired with a piece of coolant hose, the same kind you would run for heater hose, and a couple of clamps. He said it has held for him for months now.
    Years ago, in the same situation, I was too worried about heat from the exhaust manifold to try the same fix, and bought one from a JY.
      probably just the o-ring. You can get the entire tube (both ends) at a local junk yard for just a few bucks. my yards would probably be $5.
      -Bryant
        The thing is so rusted though I don't know if I could get the tube out without everything busting apart. Thanks for the replies though guys.
          Eurotiva said he has one, I can put hands on one or 7 if need be as well.
            DOH!! I didn't see this post before I replied to the other. Anyways, here's a "copy and paste" from the other post.
            Originally Posted by jimdigs
            How do I get to the O ring in this? Does the tube unscrew from the other flared tube? Thanks for the advice. Jim
            The tubes do not unscrew from each other. They are a press fit with an "O" ring to seal them together. Some wigglying and twisting will more than likely be required for separation.
            I would say probably the easiest way would be to unbolt the lower radiator hose tube from the water pump to separate the 2 sections of tubing.
            Judging from the pic you posted the tube seems rather crusty. If the inside of the tube is as bad you may have a difficult time trying to get it to seal.
            I would try the "O" ring first and if that doesn't work, eurotiva has a replacement tube.
            Or you could cut the flange off the tube and slip a piece of heater hose over the remains. I did that on my '89 a couple/few years back and it's held ever since.
            Hope this helps.
              Hope this helps.
              Thanks for the reply. It is appreciated. Do you happen to know where I would get the "O" ring I need for this? Thanks again I thought it was a hole but the "O" ring thing makes a lot more sense. While I was moving the tube around trying to get the bolt off I musta messed up the seal.
                These Festy steel B3 parts were succeeded by aluminum (the pump outlet, not the actual plug-in tubing) in Aspires and numerous Mazda engines. If your car is destined for a long-term fix start looking around for substitutions/adaptations. Up this way (the salt belt) this convoluted piece of pipe is very rust prone and subject to failure in many more places than what has happened to your's. I've used up all of my spares and so far haven't needed a new one. Rios and Mazdas have similar pipe arrangements but that will need some modification in order to use.
                Good luck!
                  It's listed under one of three water pump gaskets at my local parts store
                    Quick fix...
                    So I was sitting around last thinking what I could do for a quick fix and I remembered the sealant that I bought this summer for the leak around the top of my radiator around the plastic black tabs. It worked like a charm on the radiator. It is the sealant that is listed in the repair manual I found it on ebay. I put a picture the sealant here.
                    Anywho, last night at midnight, I'm out there gooping this stuff around the flange so it could dry overnight. Its holding so far. The coolant was just streaming out yesterday too. I drove around for about 10 miles without a problem PLUS the heat is way warmer than it was before the thermostat change.
                    Just a quick fix but it may be a permanent one if it continues to hold. We shall see. Thanks everyone for all the replies and help. It is appreciated.
