Sensei's B6 rebuild and swap
  • Sensei's B6 rebuild and swap
    My friend Brad (FF member Sensei) picked up a nice 93 GL a while back. The paint is faded but the body and interior are in great shape. The major mechanical problem? Tons of blow-by! If you pull the oil filler cap and dipstick and then crank the car you get a nice plume of white smoke shooting out of both holes. We had a vid of it somewhere that was pretty hilarious
    Since the motor needed rebuilding he opted for a little more power so we sourced a B6 from a 323 for his rebuild since it's almost a direct drop in. I didn't take any before pics of the motor during tear down but let me just say that the previous owner didn't seem worried about oil changes. Most of the rings were stuck and you could tell they either skipped or pushed an oil change or two. Luckily Mazda floods the engine with tons of oil pressure so the bearing surfaces were in decent shape.
    This thread picks up after the engine was disassembled and hot tanked. We haven't removed the old B3 engine yet but I've started the rebuild process on the B6 so it will be sitting on the stand waiting to get installed when we take the old one out.
    Here's a before pic of the engine bay with the old B3 still in the car.
    Here's a couple of pics of the bare B6 block after I honed the cylinders, a thorough washing (to remove oil and rock dust from honing), and all gasket and bearing surfaces cleaned.
    The crankshaft after a good cleaning and all the journals polished.
    One of the pistons after a good cleaning. I really wish I had taken before pics of these. It took 3 good scrubbings with SuperClean to get them looking this good. I had to clean the oil ring holes with a drill bit because they were all completely plugged and all 3 ring lands were hideous. Also note the small scores on the piston skirt.
    This is the same piston after going over it with a fine Scotchbrite pad to help polish out small scores, pits, and left over carbon deposits.
    The next step will be to inspect/rebuild the oil pump, install new rings on the pistons, and start installing the internals back into the block.
    If a hammer doesn't fix it you have an electrical problem
    WWZD
    Zulu Ministries
    Very nice Work
    1992 white L, Bp, American racing 13's, stock trans.
    1991 White L, BP/F5MR, protege header, full aspire swap with gr2's, seats, and sway bar, 15" konig's, short throw, escort console.
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
      This looks like it'll be a great thread! I have yet to rebuild an engine myself, so I'll be tuned in.
        Well it looks like you're not intimidated by using an under-maintained engine for a rebuild. Nice work. Lots of pictures too. Always good.
          ^^ I measured everything during tear down to ensure it was usable. All parts measured well within service limits so it's a good rebuildable core. The biggest issue was the dirty pistons which was solved with a good cleaning and the stuck rings which was solved today by Hastings Mfg
          ..more pics coming soon
          WWZD
          Zulu Ministries
            I started with the oil pump this morning. Here are the cleaned parts ready for inspection and reassembly.
            Measuring the wear on rotor contact to housing. Both rotor to housing and between inner and outer rotor teeth were well within specs.
            Lubed up and ready for the cover.
            All that's left now is the pickup tube and it's ready to be installed. I usually install the seal after I install the pump.
            Main bearing inserts installed into the block.
            Checking the main bearing oil clearance with Plastigage. I did all 5 mains and all 4 rods. Everything is within specs
            Rod and piston with new bearing inserts and new rings installed.
            New rings staggered, oiled, compressed, and ready to be installed into the cylinder bore.
            Rod cap ready to be installed and torqued.
            Topside with all pistons installed.
            And here's a view of the bottom.
            Up next will be installation of the oil pump, pickup tube, and front crank seal. Then the rear main seal/retainer. After that I'll finish up with the oil pan.
            WWZD
            Zulu Ministries
              Either I'm having a mental lapse or else I just didn't realise that there was a 12 valve B6. Looking good! :thumbup:
                You gotta hand it to Mazda....these B series always seem to have little to no wear, even with high miles and poor maintenance. Seems like all they ever need is cleaned, honed & new rings, bearings & gaskets.
                  there isn't, the second exhaust valve relief is there so that any piston can be used in any position...
                    For sure! I've torn down around 8 different B motors and unless they completely ran it dry of oil, all the bottom ends have been in exceptional condition for the mileage. Other than dealing with a couple of cracked blocks (due to freezing) these are some of the easiest rebuilds I've ever done :thumbright:
                    WWZD
                    Zulu Ministries
                      Who would let that happen!? :roll: Haha
                      "Lane, I've been going to this high school for seven and a half years. I'm no dummy."
                      Gone but never forgotten, "Hulkstiva"...http://www.fordfestiva.com/forums/sh...ht=progression
                        LOL Live and learn brotha! It's only a mistake if you do it twice :mrgreen:
                        WWZD
                        Zulu Ministries
                          93 build
                          Looking good brotha... Now if i can get time to take the other motor out we will be in business but (Time is coming..) :p
                            Finished up 99% of the short block today. Got everything done but the freeze plugs. Oddly enough that's been the hardest part to find for this engine. Had to order the 35mm's from AutoZone and the 30mm's from O'Reilly. Had I known they were hard to come by locally I would have ordered the 10 packs from Rock. Oh well, I'll pick them up the next time I place an order.
                            Installed the oil pump, pick-up tube, and front crank seal. Also installed the rear seal and retainer.
                            Bolted on and torqued the pan. I'll paint everything once I have the freeze plugs installed.
                            Up next: Rebuilding the head
                            WWZD
                            Zulu Ministries
                              Sweet........I have 2 questions:
                              I realized you didn't bore it, but did you check into new pistons at all? I was just wondering if there are some cheap aftermarket pistons available with less of a dish (to raise compression).
                              Also, did you (or can you) measure the deck clearance? I'm curious how far the pistons are below the deck surface at TDC.
