Easy Aspire front seat swap
  • Easy Aspire front seat swap
    Here is the easiest way to do an Aspire front seat swap. This gives you better cushioning and side support, plus generally nicer covers in terms of wear and style.
    Definitions: inboard means the side of the seat next to the central hump on the floor; outboard means the side of the seat next to the door. This is true for both front seats, since they are basically a mirror of each other.
    Tools needed:
    14mm socket.....8mm hex wrench or socket.....#2 phillips screwdriver
    needle-nose pliers.....normal flat-nose pliers.....10 blue zip ties.....1 beer
    Step one: Remove Festy seat from car, using 14mm socket; three bolts and one nut.
    Step two: Remove both (Festy and Aspire) seatbacks. Remove the plastic recliner mechanism cover; two phillips screws. Then do the inboard side; one phillips screw. On the outboard side, you need to remove the two 8mm hex bolts down where the reclining mechanism is. The front one is easily accessible with the seatback in the normal position; for the rear one, you need to recline the seat fully, so that the semi-circular ratcheting part of the recliner mechanism is out of the way. The Aspire seatback with recliner mechanism is installed as a whole.
    Step three: Remove both seat cushions and covers. On the left and right sides are five plastic pins holding the cover on. They either pull out easily or you might need the needle-nose to persuade them. Now turn the cushion over; on the bottom are ten hog rings (circular metal pieces). Use whichever pliers works better to remove them.
    Step four: Put the Aspire seat cover and foam on the Festiva metal seat bottom pan. Re-insert the five plastic pins on the left and right, and use the ten blue zip-ties in place of the hog rings (just because they are easier--you can use the hog rings if you want).
    Step five: Install the Aspire seatback onto the Festiva bottom. Do the inboard side first. Note that you have a flattish plastic piece; this goes on first, to prevent wear of the seat cover. Then the metal tube, then the hat-shaped grommet, then the screw. After that, do the outboard side. You know how.
    NOTE: If you have a separate lap belt and the automatic shoulder belt, you might want to re-use the plastic recliner cover from the Festiva, since it has a place to insert the lap belt, so you don't have to reach all the way to the floor to get at it. Aspires used integrated belts, so don't have this feature.
    This process took 30 minutes or less. Congratulate yourself on a simple and very useful upgrade by drinking half the beer. Now do the other seat.
    Nice write up!
      I believe this has also been done with the 323 seats Im curious as to what other seats it will work with. I may have to look into some 1st gen dsms or something....
        works with the escort seats as well...
          hum I will have to take a look at escort gt seats than....
            Protege LX seats too, I believe.
              good write up - nice that you took the time
              92 GL - parts car
              97 aspire - parts car
              87 323 DX - daily driver
                Thanks for the further info to add to this writeup.
                Two corrections:
                1. there are only four plastic pins on the sides of the seats, not five.
                2. on the passenger side on the Festiva seat, there is a pedal that lets the rear-seat passenger slide the front passenger seat forward. This is connected to the front passenger's hand lever for the seat slider by a metal rod. This rod needs to be removed (one small nut, maybe 5mm or so; very easy), so you can get at one of the 8mm hex bolts, to remove the reclining mechanism. The Aspire seat I used did not have that rear-passenger pedal, surprisingly. And it was from a two-door car.
                  Did this swap today. Very easy to do. Wish I had known about this years ago. No need to ride on ripped festiva seats. It just to easy to do. The rod nut is like a 9mm not a 5. I used baleing wire instead of plastic ties or hog rings. This thread needs to be a sticky.
                    thanks much for this info!
                    My Fuel Log
                    See post #10 for my tips on fuel economy
                      thumbs up
                      I used this today Huge upgrade indeed ^
                      My Fuel Log
                        Nice job!
                          Congrats! A serious design flaw in L series Festys was the self-shredding vinyl on all of the upholstery. You've corrected yours.
                            what is the weight difference between the two seat sets?
                            just to know if people are worried about adding weight.
                            Running 40psi.....in my tires.
                            http://aspire.b1.jcink.com/index.php?showtopic=611&st=0
                              Lots of Fords and Mazdas from the late 80s - early 90s. Just look for the same seatback recliner handle to see if the seat is compatible.
                              As far as weight difference, that would be negligible. Basically the same size seats.
